Server Products
Data Center Products including boards, integrated systems, RAID Storage, and Intel® Xeon® Processors
5020 Discussions
Intel 2600STBR wont startup ?
iDustBin
actually im building my new HomeServer based on Intel 2600STBR and 1x Xeon 3235 CPU.
The "PC" doesnt startup ?
I see 1 LED close to PCI Slot permanently blinking and 1x LED on Mainboard tray blinking ?
Whats wrong with my setup ?
Any idea, any hint ?
Best regards and thanks in advance
DustBin
SergioS_Intel
Hello iDustBin,
Please find our findings below:
Both the AMD Radeon™ RX 6700 - and the Samsung M393A8G40AB2-CWE (1 x 64GB, DDR4-3200, DIMM 288 pin) are not compatible with your
The 3200Mhz is not officially compatible with your platform and we cannot guarantee that 3200 MHz will not bring issues. Also, the only GPU that we have validated for the system is the following: AMD 100-505721 FirePro S7150 Graphic Card.
 Can you please try to test a Memory Type of 2666Mhz, also test the system with the minimal configuration only 1 CPU and 1 memory module of 2666Mhz? Please do not add any PCIe Card.
You can check this link for more information:
https://serverconfigurator.intel.com/exodus/page?eventType=11&targetPageId=120203109&defaultFlag=1
Also, is the system giving any beep code when turning the system on without RAM? Is there any post error message? Is it possible to get a video when you power on the system in order to have a better appreciation of what is the system showing?
We tried to see the videos sent by you before; however, they were not available.
Sergio S.
 For firmware updates and troubleshooting tips, visit :https://intel.com/support/serverbios
iDustBin
both "LEDs" are blinking
SergioS_Intel
Hello iDustBin,
Thank you for contacting Intel Customer Support.
I understand that your Intel® Server Board S2600STBR is not turning on.
I will be more than glad to help you today.
Can you please confirm if you are using an Intel® Xeon® W-3235 Processor? If so, have you tried testing a different processor on your system? Our concern is that the Intel® Xeon® W-3235 Processor is not listed as compatible for the Intel® Server Board S2600STBR, please check the list of compatible processors here:
https://ark.intel.com/content/www/us/en/ark/products/192612/intel-server-board-s2600stbr.html
Have you tried testing different components like PSU or memory?
If possible, can you please provide us a picture of lights that are blinking.
Sergio S.
iDustBin
intels page said thats code not valid
why is the cpu not compatible ? its a 3647 socket
i dont have different ram, psu is also brand new.
so you think the server doesnt start cause the cpu ?
iDustBin
SergioS_Intel
Hello iDustBin,
You are correct, the problem might be that the Intel® Xeon® W-3235 Processor is not compatible with the Intel® Server Board S2600STBR, please check the list of compatible processors here:
Do you have the possibility of testing the processor on a different system or testing a compatible processor on your board?
Sergio S.
iDustBin
so i wasted a lot of money !
ok, ill try to find a payable cpu.
can u recommend a motherboard for my xeon 3235 cpu ?
SergioS_Intel
Hello iDustBin,
Upon checking the list of compatible products of the Intel® Xeon® W-3235 Processor it seems that is compatible with systems running the Intel® C621 Chipset, you can check more information here:
https://ark.intel.com/content/www/us/en/ark/products/97338/intel-c621-chipset.html
Sergio S.
SergioS_Intel
Hello iDustBin,
We are following your thread and would like to know if you need further assistance.
Sergio S.
SergioS_Intel
Hello iDustBin,
We are following your thread and would like to know if you need further assistance or if we can close this thread.
Sergio S.
iDustBin
please wait a few days. i buyed 2x Intel Xeon Gold 6154, took a while until they arriving.
please wait, ill update here if they build in
SergioS_Intel
 Hello iDustBin,
Thank you for your updates, we will send you a follow up on 11/30/2021.
 Sergio S.
iDustBin
i buyed me 2x intel xeon Intel Xeon Gold CPUs.
Same issue as before,
ALL LEDS BLINKIG, CANT START ?
Whats the next step ? Burn this build up ?
iDustBin
? hello ?
why all leds are blinking ? whats wrong here ?
i buyed two new cpus but its not working...
whats your recommendation ? switch to amd ?
iDustBin
no ram installed: cpu fans fans start spinning: pc turned off:
all LEDs are blinking.
im freaking out
SergioS_Intel
Hello iDustBin,
We are sorry to read that you still have the same issue with the new processors, have you tried testing 1 processor at the time? Have you tried a different power supply?
Can you please provide us a picture when the error happens?
Sergio S.
iDustBin
actually i have only 1x CPU installed.
All components starts, gpu light turn on,
cpu fans start spinning.
PC turns off and all LED like before are blinking.
I removed all RAM but nothing changed.
I dont have a different PSU.
iDustBin
I can try to create a video.
iDustBin
seems to be my psu ist not compatible i cant stop laughing.
which psu should i try any recommendation ?
actually im using a be quit: dark power pro 12 but its not compatible
