Server Products
Data Center Products including boards, integrated systems, Intel® Xeon® Processors, RAID Storage, and Intel® Xeon® Processors
4544 Discussions
Intel Active System Console 4 - change the threshold value?
I had installed IASC 4 (ASC_x64.exe) from the intel installation CD came with the motherboard. My motherboard is S5000PAL and running windows server 2008 64bit. My queston is how we change the threshold value for email alerts for different components such as HDD, CPU etc.
I had consult the docs:
- enu_iasc1.pdf
- intel_active_system_console_ug_en.pdf
From the docs it mentioned i cant change the threshold if i installed with a management agent, but I only installed that single exe file.
In the past (ver 3X) i knew i can change the threshold in the registry but it'll be great if I can do it on the actual menu.
Please let me know any other workaround or other program that i am not aware of (I am avoid using system management software and microsoft system centre)
cheers
Jay
JasonT_Intel
Unfortunately there is no way to do it from the user interface. You can only customized e-mail alerts per device as an expansion of the basic alerting function of IASC 4.x.
