Hi
I have an Intel DQ45EK. On this board i have 2x2GB Transcend RAM. This worked some time ago.
Now i updated the BIOS to the newest version and now i can't install a 64-bit system anymore (tried Windows Server 2008 and Windows Server 2008 R2). They stop installing or run veeery slowly.
If i use only 2GB RAM, they work fine. I tested my RAM with memtest86+ 4.00 and they seem to be ok. memtest also run veeeeeery slowly if i have 4GB installed, if i check only 2GB at once, it works fine.
My problem seems to be similar to this:
http://forums.fedoraforum.org/showthread.php?t=157232 http://forums.fedoraforum.org/showthread.php?t=157232
Is there any possibility to use 4GB RAM?
Greets from Germany
Tobias
- Tags:
- Desktop Boards
Have you tried rolling back to an earlier BIOS?
Go back to the previous version of the bios where the rams are working. Then install the programs.
Hi
There is a new BIOS available for this board:
PRODUCTS: DQ45CB, DQ45EK (Standard BIOS)
BIOS Version 0115
About This Release:
• February 01, 2010
• CBQ4510H.86A.0115.2010.0201.1427
• ME Firmware Revision: 5.2.0.1018
• Integrated Graphics Option ROM Revision: 1940
• SATA RAID Option ROM Revision: 8.6.0.1007
• PXE LAN Option ROM Revision: Intel(R) Boot Agent GE v1.3.27
New Fixes/Features:
• Fixed issue where system takes a very long time to boot with a 64-
bit operating system.
So my problem is fixed now! I installed this version of the BIOS and it works now!
Greets Tobias
