Hi All:
Have any been across this issue with:
Intel Eth E810-XXVDA2, FW: 4.10
On an HPE XL675d H/W with Ubuntu OS.
When setting SRIOV in BIOS to disabled, OS is not able to recognize the interface but when SRIOV is enabled it is able to?
Is this a setting issue in the interface? Could it be that it is in VF mode and hence when SRIOV is disabled is not getting recognized? How to set the interface to just PF mode? Or how to disable VF(SRIOV) on the interface f/w?
Or could it be worked-around by passing a kernel parameter to the OS?
Tony
Hello TonyRacho,
Thank you for posting in Intel community forum.
We will check the details and get back with an update shortly.
Sreelakshmi
Hello TonyRacho,
To assist further, kindly confirm if the Intel Ethernet E810-XXVDA2 is embedded with the mainboard.
Sreelakshmi
Hello TonyRacho,
This is to follow up on the case. Kindly confirm if you were able to find the details we requested earlier.
Sreelakshmi
Hello TonyRacho,
Greetings for the day!
We would like to inform you that we are closing this request as no response has been received from our previous follow-ups.
Please don't hesitate to ask any further questions in the future. Feel free to start a new conversation, as this thread will no longer be monitored.
Sreelakshmi
