Server Products
Data Center Products including boards, integrated systems, Intel® Xeon® Processors, RAID Storage, and Intel® Xeon® Processors
4663 Discussions
Intel FUP8X25S3HSDK
RSump1
New Contributor III
Good morning,
When using two FUP8X25S3HSDK in an Intel P4000M chassis, I know the two cages need to be joined together by a cable with one I2C in connected to the others I2C out.
Does it matter which cage, upper or lower is cabled to the motherboard? The motherboard in question is the Intel S2600CW.
Ray
RSump1
New Contributor III
AdrianM_Intel
Hello RSump1,
It's usually recommended to cable the lower one first nevertheless there should not be issues the other way around as long as the cables have enough length.
Adrian M.
RSump1
New Contributor III
Thank you, that's what I needed to hear!
Ray
