Hello
I'm trying to boot into Altiris WinPE2 via PXE on an IBM X Series x3550 M4 server which has an on board 4 port Intel i350 Gigabit NIC. I am unable to locate a suitable WinPE 2 driver for this. The I've downloaded various I350 drivers but can't see a WinPE driver anywhere.
Is WinPE supported and if so please point me to the location of the drivers.
Thanks in advance
Nick GB
I am going from memory here and it has been awhile since i added the network drives to my PE server, but you need to use the standard drivers on the drive CD and then replace the INI file in the standard with the version in the RIS folder.
