Server Products
4761 Discussions
Intel MB S2600WF POST "Fatal error: (MEMORY) memory not detected! E8h
RNysh
The system freezes during POST startup. unable to enter BIOS. tried to reset the BIOS. The memory module is tested for compatibility with this board. On another identical server, this memory module is running. The system is new, help me figure it out.
SergioS_Intel
Hello RNysh,
In order to better assist you please help us provide the following information:
1. Can you please provide us with the model of the memory that you are currently using?
2. Is this a new installation?
3. Have you tried to test different memory on your server board?
4. Can you please provide us a screenshot of the error message?
Please try testing the system with the minimal configuration and check if the problem continues.
Sergio S.
A Contingent Worker at Intel
For firmware updates and troubleshooting tips, visit :https://intel.com/support/serverbios
RNysh
Hello SergioS
thank you for your answer.1.We try to use 32 Gb DDR4 2666 RDIMM Crucial Memory CT32G4RFD4266.36FD1 and CT32G4RFD4266.36FE1
2. Is this a new installation? Yes this is new installation.
3. Have you tried to test different memory on your server board? Yes we try 12 modules
4. Can you please provide us a screenshot of the error message? See attached pictures
We try testing the system with the minimal configuration 1 CPU 1 memory, but nothing has changed. We can't get to BIOS.
pls help
SergioS_Intel
Hello RNysh,
If you have tried different memory modules on your system and they work on an identical configuration, the problem can be related with a bad memory DIMM(s). Follow the memory population rule for your system:
https://www.intel.com/content/www/us/en/support/articles/000055509/server-products/server-boards.html
Additionally, you can check the following URL:
https://www.intel.com/content/dam/support/us/en/documents/server-products/server-boards/S2600WF_TPS.pdf
Page 56.
Sergio S.
SergioS_Intel
Hello RNysh,
I am following your question and we would like to know if you need further assistance with your serverboard.
Sergio S.
SergioS_Intel
Hello RNysh,
I am following your question and we would like to know if you were able to solve your issue.
Sergio S.
SergioS_Intel
Hello RNysh,
In case you need further assistance please contact us back.
Sergio S.
