Server Products
Data Center Products including boards, integrated systems, Intel® Xeon® Processors, RAID Storage, and Intel® Xeon® Processors
4957 Discussions
Intel Modular server Storage Pool won't let go of Hot Spare
SBerg6
We have an Intel Modular server chassis with 4 blades. I have a storage pool (storage pool 1) of disks 1,2,3 and hot-spare at disk 14. Disk 1 failed and the hotspare picked was picked up and rebuilt the storage pool. (as it should have)
But after I replaced the failed drive and rebuilt it, Storage Pool 1 refuses to let go of the hot-spare and sees it as part of the storage pool.
Any idea how to get drive 14 out of storage pool1 so I can convert it back to a hot spare?
Daniel_O_Intel
When you select drive 14 in the GUI, what options does it give you on the right-hand side? What options does drive 1 give you?
SBerg6
Thanks for the reply, Dan_O...
Drive 14 Actions (this should be my hot spare):
Identify Drive
Force Offline
Create Storage Pools
Drive 1 actions:
Same as above
When I Click the Storage pool, I have these actions available:
Rename
Delete
Identify
Create Virtual Drive
Prepare for Transport
Expand
Defragment
Create Storage Pool
If I click "Delete", it warns my virtual drives will be lost. As this is a production blade center, I cannot have these destroyed. I simply need to get drive 14 out of this storage pool so I can re-assign it as a hot spare.
Daniel_O_Intel
Weird. So, when you put a replacement Drive 1 in, I would have expected the new Drive 1 to become the Hot Spare. The RAID should have been happy on drives 2, 3, and 14.
But you say the options for Drive 1 are the same, which makes it seem like there isn't any hot spare. If you check Drives 2 and 3, do either of them have any action like "Make Hot Spare"? Or are all four drives somehow migrated into a four-drive array?
The only other thing I can think of, is to get the diagnostic summary and contact support. They can look through the history and find out what happened, and what the current state is.
SBerg6
Correct. My thoughts exactly. The Storage Pool simply added drive 14 when Drive 1 failed and after I inserted the new Drive into Drive 1, it rebuilt the storage pool with drives 1,2,3, and 14. All other drives are assigned to storage pools and have the same options.
Edward_Z_Intel
The expect behavior is that when you replace Drive 1, the array should be rebuilt back to Drive 1, and once it's completed Drive 14 will be hot spare again. What's the status of your storage pool now? What's its capacity?
