Hello guys,
I would like to use an M.2 Intel Optane on my S2600CW2R Mainboard.
My problem is that the board does not recognize the ssd.
I have already read that the board only SATA M. 2 SSDs detects what is the case with the Intel Optane. Do I have to change an Option in the Bios?
Greetings
You can't use Optane Memory on your board. The Optane Memory requires M.2 slot with PCIe interface while the M.2 slot on your board supports only SATA interface.
In addition BIOS must support Optane memory as well: SATA mode should be set to Intel RST Premium with Intel Optane.
Leon
Leon
Ah okay, I thought Optane was SATA because of the connector type.
But this explains a lot.
Thank you for your help.
Hi dr3s3l,
Thank you for your response. we are closing this request. Please don't hesitate to ask any further questions in the future.
Feel free to start a new conversation, as this thread will no longer be monitored.
Dineshbabu.
