Hello!
We first time bought a barebone R1208WFTYS with S2600WFT board.
Everything works fine and ASC shows that all is OK, but all SYSTEM FANS run always 11-12 000 rpm but status is normal. Customer is not satisfied with that, as all other brands servers are queit! All FWs are updated to the latests versions.
Any solution to this issue or it is normal?
Sergei.
Hello Franklin!
Thank you for quick reply!
We used the latest available for this board:
BIOS - 00.01.0015
ME Firmware - 04.00.04.340
BMC Firmware - 1.74.ee39402a
FRUSDR - 1.74
Sergei
Hello Franklin,
Any update? Our customer already pushing us for solution.
Sergei
Hello Franklin!
As you can mark this ticket was published on 7th of February and new BIOS release 19 of February. So we couldn't use this BIOS before.
But there is an issue with this BIOS.
Customer updated it, but the BIOS version stayed the same....15 not 16. All othe numbers changed to correct ones. But still problem is the same.
Please find screenshots attached, like what was realeased and what is the result.
Sergei
EFI method used and all components were updated. The result was the following as I sent to you. All updated, but BIOS left number left the same.
Sergei
Franklin,
I will ask customer to update the BIOS again separately. It might be that some component were not updated to the version needed, so the second run is needed probably.
Will inform you about results.
Sergei
Hello Franklin!
Customer downloaded directly S2600WF board BIOS and this time it was able to update to 16 version.
But the problem is still the same. Rpm is even 13000, maybe because it is in a rack now, but air temp is 22C, so no overheating.
Suctomer asks what is the normal speed of fan for this barebone? 5,7, 12000rpm?
Customer is quite annoyed with this server already :(
Sergei
Hello Franklin,
Customer will try re-apply FRU SDR with FAN reconfiguration.
Then he will give a feedback.
Still no additional information.
Sergei
Hello Franklin and Sergei,
How are you? Hoping you are doing well. I have R1208WFTYS system has same issue for my clients. Intel Case #: 04096693T.
This is a new system so i install BIOS form 0013 version, it is working fine, but after i upgrade to version 0014 the issue happen. I continue to upgrade to 0015 and 0016. The issue is still there.
We sold two system one is R1208WFTYS and one is R2224WFTZS, got same issue (BIOS 0014) last year. No solution for that time, we can only use BIOS version 0013 install for clients. Two month ago, Intel release BIOS 0015 so we upgrade to 0015 and then the issue happen again.
BTW, attach sysinfo_log for your reference.
Thank yo very much if you have any recommend or solution for FAN over speed (11000 RPM always).
Sincerely,
Brian Yung
