Server Products
Data Center Products including boards, integrated systems, Intel® Xeon® Processors, RAID Storage, and Intel® Xeon® Processors
4544 Discussions
Intel RAID RMS25KB040 but I do not get the BIOS access Cntrl+C
GGary
I have a Dell Precision 3420 PC which already has a RAID 1 installed via Rapid Store Technology and windows 7. I am going to install VMWare ESXi but it does not support "software" RAID. So I purchased an RMS25KB040 RAID controller and installed it. On boot, I do not see the option to get into the BIOS (Cntrl+C). Would anyone know why? I am concerned that this LSI chipset is not supported by this motherboard. I also wondered if I would have to Disable the RAID on the Main Board? Is it possible that the on-board RAID is stopping the newly installed RMS25KB040 RAID controller from working.
Hello garyal,
Let me transfer this to the servers Communities, they are in charge of RAID controllers :)
Esteban C
GGary
Thank You. Any information would be very helpful.
Just some extra information. I left the RAID card in and booted into Windows just using the on-board hard drive controller. When I went into Device Manager I could not even find the new RAID card. It almost appears that the main board does not even see this RAID card. I have it installed in a PCIe (x16) slot and I can see the amber light flash when I power the computer so I know it is powered.
Cesar_B_Intel
Hello Gary,
Please try removing and reseating your https://ark.intel.com/products/60289/Intel-Integrated-RAID-Module-RMS25KB040 Intel® Integrated RAID Module RMS25KB040 and if not recognized, you could try placing it on another PCI slot. Supported PCI E slots are x8 and x16 (slots). You could try changing the RAID mode in the BIOS and selecting AHCI option to force the motherboard to use/initialize https://ark.intel.com/products/60289/Intel-Integrated-RAID-Module-RMS25KB040 RMS25KB04 drivers.
It is recommended to check compatibility of https://ark.intel.com/products/60289/Intel-Integrated-RAID-Module-RMS25KB040 Intel® Integrated RAID Module RMS25KB040 with your Server Manufacturer. I confirmed Dell Precision T7610 is compatible with at http://i.dell.com/sites/doccontent/business/smb/merchandizing/en/Documents/Dell_Precision_T7610_Spec_Sheet.pdf http://i.dell.com/sites/doccontent/business/smb/merchandizing/en/Documents/Dell_Precision_T7610_Spec_Sheet.pdf however, it has a different chipset than Precision Tower 3000 Series (3620)
These are the requirements for installing the https://ark.intel.com/products/60289/Intel-Integrated-RAID-Module-RMS25KB040 Intel® Integrated RAID Module RMS25KB040
• Intel® Integrated RAID Module RMS25KB080, RMS25KB040, RMS25JB080 or RMS25JB040 (SAS/SATA cables need to be prepared separately).
• A supported host system with an available x8 or x16 PCI-Express* slot for RMS25KB080 and RMS25KB040, or an available SAS Module Connector for RMS25JB080 and RMS25JB040.
• Resource CD, which contains drivers and documentation. Which are available from https://downloadcenter.intel.com/download/25107/Intel-IT-IR-SAS-driver-for-Windows- https://downloadcenter.intel.com/download/25107/Intel-IT-IR-SAS-driver-for-Windows-
• SAS or SATA hard drives up to 6 Gb/s speed.
• SAS/SATA cable accessory kit, which can be ordered from Intel separately. Please see the Tested Operating System List for available cable accessory kits at http://www.intel.com/p/en_US/support/server http://www.intel.com/p/en_US/support/server.
Note: Intel Corporation strongly recommends using an uninterruptible power supply (UPS). The Resource CD is shipped with systems or boards that support Intel® Integrated RAID Module RMS25KB080, RMS25KB040, RMS25JB080 or RMS25JB040.
Additional information is available at http://www0.sun.ac.za/itservices/Documents/datasheets/2016/Dell/Desktops/Dell_Precision_Tower_3620.pdf http://www0.sun.ac.za/itservices/Documents/datasheets/2016/Dell/Desktops/Dell_Precision_Tower_3620.pdf
and http://download.intel.com/support/motherboards/server/sb/486189_g42520_002_rms25kb080_rms25kb040_rms25jb080.pdf http://download.intel.com/support/motherboards/server/sb/486189_g42520_002_rms25kb080_rms25kb040_rms25jb080.pdf
Please let me know if you have any questions.
Caesar B.
GGary
Thanks so much for looking into this Cesar. I appreciate it.
I will try that AHCI option since I have NOT attempted that BIOS setting yet. I have tried Disabling the RAID but not setting the BIOS to AHCI.
Last night, I tried to simply install ESXi Hypervisor hoping that it would just see the RAID array and install but no luck. When ESXi scanned for storage devices to install on, it did not find any drives at all. This leads me to believe that the main board does not recognize this RMS25KB040 RIAD controller card.
If the AHCI BIOS setting does not work, I will look into upgrading to either a server-class computer or possibly look into a compatible Dell PC model such as the T7610 as you mentioned above.
Thanks again for the information.
You are welcome. Please try changing the Setting in the BIOS to AHCI and let me know of the results.
If you have any more questions please let me know.
Caesar B.
KL2
Valued Contributor I
There's a warning sticker on the box for Intel RAID 'Module / Mezzanine' adapters (RMSxxxxx), that states they only function on Intel Servers and such:
Cesar_B_Intel
Hello Gize2 ,
Thank you for sharing this information.
Caesar B.
