Server Products
Data Center Products including boards, integrated systems, Intel® Xeon® Processors, RAID Storage, and Intel® Xeon® Processors
5006 Discussions
Intel Raid Card RMS2LL040
We using Server Board S1200BTL, Raid Card RMS2LL040 and Seagate Constellation ES ST1000NM0001. It's take 2 days to initialized the brand new HDD. Make us crazy....
Edward_Z_Intel
Did you select "Fast Initialize" when creating the VD?
There have no option for me when creating the VD.
Edward_Z_Intel
My bad - I mixed it with an ir3 controller. Sorry about that.
Several questions:
Which kind of RAID are you using, IM/IME or IS?
Have you updated the http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=20393 firmware of RMS2LL040?
Have you tried a drive from the http://www.intel.com/support/motherboards/server/sb/CS-031779.htm Tested hardware and operating system list?
Are you using a hot-swap backplane?
Thanks for your reply.
We're using:
Server Board : S1200BTL (Firmware : S1200BTL_SUP_EFI_BIOS30_BMC1_10_FRUSDR1_09(Ver: 30;1.10;1.09) and S1200BTL_BIOS28_BMC_01_07_FRUSDR_01_07(Ver:28;1.07;1.07)Intel Raid Card (RAID 1) : AXXRMS2LL040 (Firmware : EPSD_SAS2_FW_ph10_2011.07.08, V7.19.00.00, 2011.05.16) with SAS cable directly connect to raid card.RAM : KVR1333D3E9SK2/8G (16GB)HDD : Seagate ST32000444SS Note: We have tested with RMS2LL040 old firmware(V7.05.01.00, 2010.02.09). It's just take 10 hours for 2TB (SAME HARDWARE). It's looks like is the new firmware issues.
Hi,Can you help us please to connect SAS HDD to AXXRMS2LL040 ? We are using:Server System R1304BTLSFANIntel Integrated Server RAID (0, 1, 1E) Module AXXRMS2LL0402x 1TB SEAGATE SAS 64MB 7200PRM ST1000NM0001 AXXRMS2LL040 uses 7 pin SATA connectors, R1304BTLSFAN have sata power connectors but SAS HDDs have SAS connector, not SATA. How did you connect ?
Edward_Z_Intel
Ideally the fixed drive bay support SATA drive only. If you want to use SAS drive you should use a SAS/SATA backplane (with R1304BTLSHBN system).
However, you may want to take a look at the SAS-SATA adapter below, although I'm not 100% sure whether it will fit the drive bay or not:
http://www.scsi4me.com/hp-398291-001-sas-sata-adapter-for-sas-hdds.html http://www.scsi4me.com/hp-398291-001-sas-sata-adapter-for-sas-hdds.html
I confirm that it works.
Thank you !
