Server Products
Data Center Products including boards, integrated systems, Intel® Xeon® Processors, RAID Storage, and Intel® Xeon® Processors
4658 Discussions
Intel S1200BTS motherboard CPU compatibility?
I want to ask does the Intel S1200BTS motherboard support the below processors?
- Intel G620T - Intel G630T - Intel i3-2120T
I found this (http://www.intel.com/support/motherboards/server/sb/CS-032414.htm http://www.intel.com/support/motherboards/server/sb/CS-032414.htm), but I have doubts because the user manual (http://download.intel.com/support/motherboards/server/s1200bt/G13326-003_S1200BT_TPS_v1_0.pdf http://download.intel.com/support/motherboards/server/s1200bt/G13326-003_S1200BT_TPS_v1_0.pdf) does not mention the Intel Pentium Desktop processors and the newer 2nd i3 "T" processors.
Thanks in advance for your help.
P.S.: Sorry for my bad English.
Edward_Z_Intel
Follow the tested processor list http://www.intel.com/support/motherboards/server/sb/CS-032414.htm http://www.intel.com/support/motherboards/server/sb/CS-032414.htm. New processors will be validated and added to the list.
