Server Products
All support for Intel NUC 7 - 13 systems has transitioned to ASUS. Read latest update.
4732 Discussions
Intel S1200SPS sometimes hanging on restart with POST code 96h
MMich29
Build:
Intel S1200SPS Server Motherboard
Xeon E3-1245v5
Kingston ValueRAM 2x8GB DDR4 2133MHz ECC
Samsung 850 Pro
2x WD SE 1TB HDD in RAID 1
Windows 10 Professional
The problem happens when selecting restart from Windows. Sometimes, but not always, the computer will hang on the Intel splash screen with Post error 96h. Pulling the power completely fixes the issue. We have swapped out the board as recommended by the troubleshooting guide for that error code as well as removing and swapping drives. We have also tried using a different power supply. Board is on the latest firmware. Any idea what may be causing this?
Also as a possibly unrelated issue; Serial IO I2C Host Controller -A160, Serial IO I2C Host Controller -A161, Serial IO UART Host Controller - A127 all show in Device Manager as Code 12: This device cannot find enough free resources that it can use. This happened with both boards. Not a huge issue as serial will not be needed, but I though it worth mentioning.
Please take in consideration that the Xeon E3-1245v5 is not listed as tested&compatible for the board according to the http://ark.intel.com/products/88272/Intel-Server-Board-S1200SPS# @compatibility ark website.
Our recommendation to start narrowing the issue is testing the board with a fully validated processor and minimum memory installed.
