Hello there,
We have a bunch of S2600BPB blades. We have a need of enabling Configuration --> Security Settings --> RMCP+ Cipher Suite3 Configuration for each LAN channel --> tick Channel 1 Enable on all the blades. Since we have 100s of them, we cannot login into each BMC console and do it which is very time consuming. Is there any other way of doing this? Via ipmitool or syscfg or by any other means?
Please help me out.
Found the solution over here at https://groups.io/g/OpenHPC-users/topic/32590189?p=Created,,,20,2,0,0::,,,0,0,0,32590189
Hello sskamesh,
Thank you for joining the community
This is the Syscfg user guide. intel-syscfg-userguide-v1-03.pdf You can look for the for the command you are looking for.
This is the IPMI Technical Resources (intel.com). You can take a look here and even ask to the Intel Developer Forum.
Jose A.
For firmware updates and troubleshooting tips, visit:
https://intel.com/support/serverbios
Okay, thanks. Let me make a post in Intel Developer Forum.
Hello sskamesh,
Been that the case we will proceed to mark this thread as resolved. If you have further issues or questions just go ahead and submit a new topic.
Jose A.
