Server Products
Data Center Products including boards, integrated systems, Intel® Xeon® Processors, RAID Storage, and Intel® Xeon® Processors
4613 Discussions
Intel S5000PSL support for E5430 CPU ?
dshma
Hello!
I have 2x5110. LGA771 socket.
BIOS version: s5000.86B.15.00.0101 11/09/2010.
I bought and insert 2xE5430 lga771.
But i have errors in BIOS: 19A, 19F, 19A.
What can i do?
Hello inusr,
Hope you are doing fine.
Let's try with one processor first.
Then please perform a CMOS clear by using the jumper J1D1.
Update the latest firmware by following thishttps://downloadcenter.intel.com/download/19672/?product=46544 link.
Then access the BIOS settings again and if it works add the second processor.
Please let us know how it goes.
Charlie_Intel
dshma
"Update the latest firmware by following thishttps://downloadcenter.intel.com/download/19672/%3Fproduct%3D46544 link."
Here bios 101 version.
I have already bios version 101.
Also, i cleared cmos by F9.
Hello inusr,
According to the image sent, you have the version 101 yes but, may not have the FRU and BMC updated as the date showing is not the same to the latest, we need you to perform the complete update again using one processor and the lowest configuration
Charlie_Intel
dshma
My steps:
1. Insert 1 proc E5430. Only one.
2. Clear cmos by jumper (power off, change j1d1 from 1-2 to 2-3. power on. 10 sec.power off. change jumper from 2-3 to 1-2. power on.)
3. Update BIOS101 + BMC66 + FRUSDR48
4. Power off, power on.
If all good thne insert secons proc e5430 and see.
All right?
Hello inusr,
That is correct.
Best regards
Charlie_Intel
dshma
Hello!
I tried.
I updated by Intel Assistant.
Firmware https://downloadcenter.intel.com/download/19609/Firmware-Update-Package-for-the-Intel-Deployment-Assistant-and-Intel-One-boot-Flash-Utility?product=46544 this.
But I still have an processor error (((
Before update firmware:
After:
earlier(2012 year) I updated from under dos and have version 101 68 48.
now i have version 101 66 48.
But, for the last week I inserted a new processor when the version was 101 68 48 and it did not work....
Hello inusr,
Can you try to perform the BIOS update using EFI?
Then perform a clear C/MOS and clear SEL in the BIOS, then test again.
Charlie_Intel
dshma
board part number - D44771-001
board serial number - QSSL63200543
bmc firmware - 0.68
hsc firmware - 2.02
sdr - src package 48
is it ok for E5430 + s5000psl?
can i try update by efi and this https://downloadcenter.intel.com/download/19672/Firmware-Update-Package-for-DOS files?)
Hello inusr,
Yes, please proceed with the update.
We recommend you to read this https://downloadmirror.intel.com/19672/eng/Software_Update_23_Instructions.txt file.
And that is correct according to the model, that board should be compatible with E5430 Processor.
Charlie_Intel
Hello inusr,
We are wondering if the information provided worked for you?
Charlie_Intel
dshma
Hello!
I'm waiting.
I'm waiting for then i can get server into my hands.
Peoples work 20 hours per day ((((
I will give you answer.
Hello inusr,
Perfect, we will be waiting please take your time.
Charlie_Intel
dshma
Hello!
For update firmware i must have Update Package for UEFI. But i no have this package for my MB s5000psl.
I have only dos package for dos-update.
Hello inusr,
You need to create a bootable DOS USB Disk-On-Key Device first.
Charlie_Intel
dshma
Yes. I created dos usb flash bootable and updated bios-bmc-frusdr.
Now i have 101-68-48 and new processor not work(((
i updated bios, reboot, clear cmos.
update mbc and frusdr. reboot.
insert new processor.
and see erros processor(((
Hello inusr,
What is the error that is showing?
Charlie_Intel
dshma
Do you have fast contact? for example skype/whatsapp?
19a -fatal
19f - major
dshma
If i insert one e5430 and try boot flash, system wrote: unrecoverable fatal error found. system will not boot until the error resolved.
press f2 to enter setup.
so, i updated then inserted 2 older proc.
during update, jumper bmc_force_update is 1-2.
Hello inusr,
Try a CMOS clear, by the jumper, and into the BIOS use the 'Processor Retest' option.
Charlie_Intel
dshma
Done.
No results.
Remove power.
Removed both 5110.
Insert one intel'06 e5430 intel xeon slbbk costa rica 2.66ghz/12m/1333 3837b322.
Jumper cmos to 1-2 from 2-3.
Insert power. wait 2 min. remove power.
Jumper cmos to 2-3 from 1-2.
power on.
enter to bios and Processor retest to ENABLE and have error 5220.and reboot.
after reboot i have error 9268.
reboot and have 19a, 19F errors.
