Server Products
Data Center Products including boards, integrated systems, RAID Storage, and Intel® Xeon® Processors
5056 Discussions
Intel S5000PSL windows server 2008r2 need help cant find drivers for install
Im trying to install windows server 2008r2 on this machine and i get to the install now and then it wants drivers ive looked through every driver on intels site i also tried server2003 and above does anyone know the correct drivers for the machine for sata so i can install this pleaseeeee
Intel S5000PSL
if you have a better way to mount it to usb id gladly try that if that is the problem
OK will try that keep achi on? And enhanced mode as well on ?
Edward_Z_Intel
If AHCI is on, you need to load AHCI driver. If AHCI is off, no driver is needed. Enhanced mode should always be on.
I just tried taking my hard drive out of my main pc windows 7 ultimate and I have achi off and it does starting windows and restarts does that mean anything ?
Edward_Z_Intel
Well at least it means your SATA port is working.
yeah i was able to get vmware esxi on there but even then it wants drivers and it wont take em on there as well in its own vm im loading the iso to the microsoft tool
ok its working now not running in achi and but its running 2008 now and the yumi multboot was the issue lol thank you very much
