I have a problem with Intel SASWT4I RAID controller. The controller is in the resyncing state and I'm unable to access RAID BIOS utility by pressing ctrl+c. The message says that the utility is being loaded but then it says "No Boot Device Found". If I don't attempt to get to the utility, it will boot to the windows.
I'm using MSI board and two Intel 320 series SSD drives.
Any ideas why I would not be able to access BIOS utility??
Thanks!
Did you try to run http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&ProdId=3054&DwnldID=18440&ProductFamily=Serve... RAID Web Console 2 to check the status of the controller, or update the http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&ProdId=3054&DwnldID=19804&ProductFamily=Serve... RAID controller firmware?
We did update firmware and still no go. We even wiped the SSD's and bypassed backplane and still can't get to RAID Utility by pressing CTRL+C. The next step is to try regular hard drives. Any ideas what went wrong? It worked fine for 2 weeks, and now it doesn't.
