Server Products
Data Center Products including boards, integrated systems, Intel® Xeon® Processors, RAID Storage; and Intel® Xeon® Processors
The Intel sign-in experience is changing in February to support enhanced security controls. If you sign in, click here for more information.
4482 Discussions
Intel SC5600 (or 5650?) Chassis - Front i/o connector
Hi there
Resently I retired (ruined) a Intel SE7505VB2 board that was in my home server.
The case has a front I/O panel with the led's for NIC, HDD etc and all the buttons (NMIK, sleep, power and reset) and the se7505vb2 has the associated Front Panel connector on it
The board I bought as a cheap replacement for the board i ruined was the MSI MS-9138 Motherboard Memory E7501 Master-LS2 which does NOT have the front panel connector, nor does the cable fit
I have a wealth of technical skills as I plan to splice the cable and run the correct wires to the correct plug on the new (old) motherboard. I've searched everywhere, including google cache as old as i could go.
I need a pinout
Edward_Z_Intel
The connector is a standard 34-pin SSI connector. It's documented in section 8.7 of http://www.intel.com/support/motherboards/server/se7505vb2/sb/cs-007399.htm board TPS.
Edward_Z_Intel
Thank you kindly Edward. I had skimmed thru this and missed it, due to the fact I was really only looking for the terms pinout (not pin-out) ...
Also for clarity sake, if you don't mind. ACPI_switch refers to PWR_switch?
Happy face Edward, Happy face.
Edward_Z_Intel
