Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
Intel SS4000e disk change notification bug
hi,when I log on to the SS4000e array web interface I get a screen called Disk Change Notification.
Whatever I do, I keep getting back to that screen. I have a configuration with 4 x 500 GB HD
that has been running fine for 18 months, reboot every 2 months. I tried swapping disks around
, the array would rebuild and then again give the same screen. I tried reinitliaizing the entire array,
same screen.
Anybody know of a fix? I saw some users on the web with the same issue but no real
solutions as far as I could see.
Thanks in advance,
Bob
Do you still have access to your data on the storage? If yes, I suggest you do a complete backup of the data and upgrade to http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&ProdId=2366&DwnldID=16833&ProductFamily=Serve... Firmware 1.4 following the steps in the http://downloadmirror.intel.com/16833/eng/SS4000-E_SW_Release_Notes-release1.4.pdf Release Notes.
Take note that the update process is destructive. All data on the hard drives will be removed.
Community Manager
Hi Edward, thanks for your answer.
I have now tried :
- degrading the RAID (taking out 1 and more disks), that didn't work, I still got the disk change notification screen, the
raid will rebuild but afterwards I still get the screen
- taking down the RAID (i.e. taking out all the disks and putting back one). I created a partition on that one drive,
still got the screen afterwards
- i put all 4 disks back in and recreated a RAID 5 array. This took about 24 hours to rebuild, after which I still
get the screen.
What's the best way to upgrade the unit, as I currently do not have access to the admin interface? Can it be
done through FTP or similar?
Thank you! S
