Server Products
4784 Discussions
Intel SSD P3520 1.2TB
suser1
Would an Intel SSD P3520 1.2TB drive - PCi-e 3.0 (4x) fit a 2U case and is it compatible with an intel 2600CW2S motherboard? I see the motherboard only has PCIe Gen III x8, and PCIe Gen III x16 slots.
In other words are PCIe Gen III x8 and PCIe Gen III x16 compatible (both technically and physically) with the lower speed PCIe Gen III x4 drive?
Also do I understand correctly that the form factor of the hard drive (HHHL (CEM2.0)) means it would be able to fit a 2U server?
Thanks in advance.
Hello Some-User,
According to the ark.intel.com repository the Intel SSD P3520 series hdds are fully compatible with the S2600CW2S board, no matter whether installed on a 8x or 16x slot. You can confirm this on the following URL: http://ark.intel.com/products/88732/Intel-SSD-DC-P3520-Series-1_2TB-2_5in-PCIe-3_0-x4-3D1-MLC http://ark.intel.com/products/88732/Intel-SSD-DC-P3520-Series-1_2TB-2_5in-PCIe-3_0-x4-3D1-MLC under Compatible Products.
About the form factor most likely you will need to install the SSD using one of the PCI riser cards that come on the chassis. If you want to get more info about this go to https://www.intel.com/content/dam/support/us/en/documents/server-products/server-boards/Intel_Server_System_R2000WT_TPS_R1_04.pdf https://www.intel.com/content/dam/support/us/en/documents/server-products/server-boards/Intel_Server_System_R2000WT_TPS_R1_04.pdf . In section 10 it details the PCI riser cards. Also take into consideration that depending on the amount of processors you have installed some features or PCI slots might not be available. For mor info check https://www.intel.com/content/dam/support/us/en/documents/server-products/server-boards/Intel_R_Server_Board_S2600WT_TPS_R1_5.pdf%20section%202.2 https://www.intel.com/content/dam/support/us/en/documents/server-products/server-boards/Intel_R_Server_Board_S2600WT_TPS_R1_5.pdf section 2.2.
Hope this helps.
Jose H.
Hello Some-User,
We understand you have some questions about compatibility with the Intel® SSD DC P3500 and the Intel® Server Board S2600CW2S.
In this case, we would like to refer you to our /community/tech/servers servers team, we will be moving this thread.
Nestor C
Hello Some-User,
Hope this helps.
Jose H.
Hello Some-User,
Do you have any updates in regards to this? Just let me know.
Jose H.
suser1
Thank you, I have purchased and installed the device. It is working without any issues. I only had to change the BIOS to UEFI mode to allow booting from the device.
Thank you.
Hello Some-User,
Thanks for the update. I will proceed to mark this thread as resolved.
If you have any other questions do not hesitate to create a new topic.
Jose H.
