Server Products
Data Center Products including boards, integrated systems, Intel® Xeon® Processors, RAID Storage, and Intel® Xeon® Processors
4829 Discussions
Intel® Server Board S1200SPL and Intel Xeon E3-1245 v5
SAzna
I have a problem. Don´t work. I'm trying connect hardware but the motherboard beats, is it incompatible?
AlHill
They are compatible.
https://ark.intel.com/products/88263/Intel-Server-Board-S1200SPL Intel® Server Board S1200SPL Product Specifications
Look under "compatible products"
Doc
SAzna
Excuse me! I wanted to say Intel® Server Board S1200SPLR, it's compatible?
Hello Salvador,
The Intel® Server Board S1200SPL is indeed compatible with the Intel Xeon E3-1245 v5, you can confirm this information https://ark.intel.com/products/88263/Intel-Server-Board-S1200SPL here.
Please help us provide some additional information in order to narrow down your problem:
1. How many beep codes are you getting? Please check the https://www.intel.com/content/www/us/en/support/articles/000006001/server-products.html POST Error beep codes for Intel(R) Servers article, for additional information.
2. Can you please provide your memory part number?
3. What's the wattage of your power supply?
4. Is this a new installation or was your system working before?
Sergio S.
SAzna
Is a new installation.
https://ark.intel.com/products/97950/Intel-Server-Board-S1200SPLR server board: Intel® Server Board S1200SPLR Product Specifications
Processor: https://ark.intel.com/products/88173/Intel-Xeon-Processor-E3-1245-v5-8M-Cache-3_50-GHz Intel® Xeon® Processor E3-1245 v5 (8M Cache, 3.50 GHz) Product Specifications
Crucial Memory DDR4 2133 PC4-17000 8GB CL15 P/N: CT8G4DFS8213 http://eu.crucial.com/eur/en/ct8g4dfd8213# productDetails Crucial 8GB DDR4-2133 UDIMM | CT8G4DFD8213 | Crucial EU
Error beap code: beats 1-5-2-1
Hello Salvador,
The beep code sequence 1-5-2-1 means that there is a CPU socket population error, please make sure that your processor is properly seated on the server board.
Also, test your system without any memory, you should have 3 longer beeps, this means that the server board is detecting your processor.
You can also test your system using one memory DIMM, and make sure to populate the one that is closest to the processor
Are you getting any lights or fan activity when you try to turn your system on?
Have you tried testing different components on your system?
What is the wattage of your power supply?
Sergio S.
SAzna
Hi Sergio, by resetting the bios I have managed to make the motherboard not beep. I have been able to install windows server but when turning on the PC some LEDs light up.
- The system status ley is blinking green.
- The upper nibble, leds # 4 # 5 # 6 # 7 is blinking amber
- The lower nibble leds, leds 3# # 0 solid green
What happens?
Hello Salvador,
Please check the https://www.intel.com/content/dam/support/us/en/documents/server-products/S1200SP_TPS_R1_1_S1200SPL_S1200SPS_S1200SPO.pdf technical product specification in order to find the different meanings of the system LED indicators. Page 89.
If you are getting a solid green means that your system is ready to boot.
The blinking amber lights mean that the system is operating in a degraded state with an impending failure warning, although still functioning.
Sergio S.
SAzna
Hello Sergio,
The four leds in amber blinking do not match any post code diagnostic...
I upload a video of when the pc is turned off:
Hello Salvador,
When you turn your system are you getting any fan activity?
Have you tried testing a different power supply and memory?
Test also your system with no memory, you should get 3 long beeps, this means that the desktop board is detecting the processor and is checking for the memory.
Sergio S.
SAzna
I have tried to remove the memory and that the desktop is detecting the processor.
When you turn on your system if the fans work, and and the green LED blinks.
I tried testing a different power supply and memory, but with the same result.
The components of my server are the following:
chasis: corsair air 240
processor: intel xeon e3 1245 v5
server board: intel server board s1200splr
Power supply: be quiet pure power l8 430w
memory ram: kingston value ram ecc KVR21E15D8/8
Boot video:
https://www.youtube.com/watch?v=nQaCM0bluh8&feature=youtu.be
Thankss.
Hello Salvador,
I hope you are doing well today.
Thank you for your update. Based on the information you provided, can you please proceed and test the server board out of the chassis?
Basically, you put the server board on an isolated surface and test it first only with the CPU, it should give you a beeping sound. Then test it with one memory stick at a time.
Please let me know your results.
Jeremiah A.
Intel(R) Technical Support
Hi Salvador,
I'm following up with you to see if the information helped or if you still require more assistance from us.
Jeremiah A.
Hi Salvador,
Jeremiah A.
Hi Salvador,
I have not heard back from you in regards to this issue. I will proceed in closing this case. If you need more assistance from us feel free to contact us again
Jeremiah A.
