Server Products
Data Center Products including boards, integrated systems, Intel® Xeon® Processors, RAID Storage, and Intel® Xeon® Processors
4657 Discussions
Intel® Server Board S2600CW2S - RAID IT Mode
suser1
I currently have an Intel® Server Board S2600CW2S, I would like to configure ZFS on some of the hard disks linked to the LSI embedded controller. Would I be required to flash the on board RAID controller specifically to IT mode to allow passing through each drive independently or would this not be necessary eg. I only have to select software mode in the BIOS?
Hello Some-User:
There is no actual updatable embedded RAID firmware. What could be updated is the board firmware but it is not necessary to do it in order to enable any of the software RAID modes. The current modes available are AHCI (no RAID individual drives), RAID 0, 1 and 5. For information about how to enable and setup the embedded server RAID controller check the following document: http://www.intel.com/content/dam/support/us/en/documents/server-products/ESRT2_Software_UG.pdf http://www.intel.com/content/dam/support/us/en/documents/server-products/ESRT2_Software_UG.pdf
Hope this helps
Jose H
Hello Some-User,
Do you have any updates or questions about this? Please don't hesitate to ask.
Jose H.
