Recently I picked up a used board Intel® Server Board S5500WB, little did I knew this board as 12V version. I thought its going to be another board with standard power connector, I could use a high power ATX PSU to supply it.
Now how can I power up the motherboard ? I have a PSU which has dual 12V output. Is that all needed to start the board ?
http://manuals.ts.fujitsu.com/file/9269/cx120s1-d3052-intel-tps-en.pdf http://manuals.ts.fujitsu.com/file/9269/cx120s1-d3052-intel-tps-en.pdf
I wanted this system with dual xenon and 16GB RAM for video encoding.
Thank you for your help.
regards,
Dwija
Hello Dwija, thanks a lot for posting your question at Intel communities.
I would like to inform you that I have moved your post to the Server Community at the following URL /community/tech/servers https://communities.intel.com/community/tech/servers
Regarding you question it looks like an Auxiliary power connector is also needed. Please check this link. At the bottom you will be able to see a box that says "Making connections to the server Board… Quick Reference"
