Hi
Server board: SE7520AF2
This server has been running fine for years up until today when I rebooted it remotely to find a black screen on the display.
I rebooted several times, and no BIOS screen appears.
the LED diagnostics on the board show;
BIT 4 (MSB) = RED
BIT 3 = RED
BIT 2 = AMBER
BIT 1 (LSB) = AMBER
the LED lights flash in different sequence every so often.
When I remove all RAM, receive beeps which I understand means the mainboard isn't fried.
I have removed all RAM and seated only 1 piece into the first slot. No good
I have formatted USB key using FAT16 , and copied the AMIBOOT.ROM to the USB key, changed jumper J1D1 to recovery, however do not know of the recovery bios loads (waited 5 mins when returned jumper back and still no luck on reboot)
RAM i'm using : samsung 1GB 1Rx4 PC2 3200R 333 10C1
please help as server is down!
The Diagnostic LED translates to POST code F3, which means "Start reading the recovery file cluster by cluster". Do you also get the same code when you put the recovery boot jumper to normal boot position (J1D1, 9-10)?
You can also try to move the Rolling BIOS Bank Selection jumper (J2J6) to position 2-3 to force the board to boot from Bank 0.
Hi
1. When do this, "You can also try to move the Rolling BIOS Bank Selection jumper (J2J6) to position 2-3 to force the board to boot from Bank 0. " , we get these diagnosic LEDs
BIT 4 (MSB) = RED
BIT 3 = AMBER
BIT 2 = OFF
BIT 1 (LSB) = OFF
2. Put jumper (J2J6) into original possition, and J1D1 is set tp normal boot - 9-10
same LEDS on boot up, as above
BIT 4 (MSB) = RED
BIT 3 = AMBER
BIT 2 = OFF
BIT 1 (LSB) = OFF
This is still with one memory stick in first bank.
Note if I swap the memory piece (exactly sme type) , I get diffrent LED's
BIT 4 (MSB) = RED
BIT 3 = RED
BIT 2 =AMBER
BIT 1 (LSB) = AMBER
It appears one of the memory modules is possibly faulty? But why can't the system boot with a working module???
Please advise next step
Hi
The server appears to be booting now.
Not sure what resolved it, but here where my last steps;
Plugged in power
Set (J2J6) to position 2-3 to force the board to boot from Bank 0.
Set J1D1 to recovery
inserted USB drive with ROM
booted up, waited for a bit
nothing happed,
Restored jumpers above to original position, and booted....intel logo appeared happy days
What I have noticed is that if you plug in the power, then boot the server BLANK SCREEN appears.
If you then hold down the power button on chassis to power down, then power up again using the same button the server boots > weird!!!
I'm able to replicate this behavior each time.
Anyway server is running which is the main thing. thanks for help
