Server Products
4784 Discussions
Intel Server Motherboard S5520HC Memory Confusion
SDoug3
When I run the memory checker utility for an Intel S5520HC motherboard I get the error "the dimm is populated without a processor in socket 2." I have three RDIMMs from Kingston (KVR1066D3Q8R7SK3/12GI). No matter what combination of order I place them into the dimm sockets, I continue to get the error message.
The graphic shows the problem I am having. It states "processor socket 2" is populated. I don't have a processor in the second processor slot. It is in the "CPU 1" slot. The memory is quad rank, 4GB each, and speed of 1066 frequency.
I hope this is descriptive enough. If not, please let me know if there is anything else you may need and thanks.
Daniel_O_Intel
Did you populate this processor socket, and these DIMM slots? (image taken from TPS at http://www.intel.com/support/motherboards/server/s5520hc/sb/CS-030223.htm http://www.intel.com/support/motherboards/server/s5520hc/sb/CS-030223.htm , page 6 (20 of 190) )
