Server Products
Data Center Products including boards, integrated systems, Intel® Xeon® Processors, RAID Storage, and Intel® Xeon® Processors
4616 Discussions
Intel Server Taking a long time to post
DVale3
I have a server with the following specs
SDR Version SDR Package 0.17BMC Version 1.19HSC Version 2.15CPUIntel(R) Xeon(R) CPU X3430 @ 2.40GHzOperating System NameMicrosoft Windows Server 2003, Standard Edition Service Pack MotherboardS3420GPCBiosS3420GP.86B.01.00.0042Memory4GB DDR3 1067Raid ControllerSRCSATAWB Firmware 1.40.92-0746Hard Drives6 x SATA 500GB 7200RPM Drives RAID 5 with Hotspare
When i restart the server it takes about 7 min before i hear the beeps then the intel logo flashes. Anyone else experiencing long post times on this board.
Daniel_O_Intel
I would first update to the BIOS 51 package, then do a test boot without the RAID controller or any USB devices attached, and the memory temporarily removed
You should get three beeps within maybe thirty seconds of power-on. If you do, add the memory back in and do a test boot, then proceed doing one bit at a time.
