I have made a server setup with 2 xeon e5 2620-v4 processor.
my pc starts but stuck at boot. USB ports are not working as keyboard and mouse are not working. screen stuck at
"Warning: This server is running factory firmware.
A software update is required.
Please load the latest system update package(SUP)
to unable the latest security, quality and performance capabilities.
Hello ravindrao5 ,
Can you perform the following steps in order to update the BIOS?
- Download the latest firmware for Extensible Firmware Interface* (EFI*) from the support site.
- Unzip the package and copy all files to a folder on a USB device.
- Insert the USB device to the server/workstation USB port.
- Boot the server to the EFI shell.
- Run the map -r command in EFI shell to map USB device.
- Run the fs0: command to change folder to USB device. USB device can also map to fs1:. The number of the fs# is dependent on the result of the map -r command.
- Change the folder to the folder storing the firmware package.
- Run the startup.nsh command to start updating all the firmware and BIOS.
https://downloadcenter.intel.com/download/28004/?product=88276
Charlie_Intel
Hello ravindrao5,
We are wondering if you were able to perform the troubleshooting steps?
Charlie_Intel
Hello ravindrao5,
We are wondering if you need further assistance?
Charlie_Intel
Does this mother board supports non ecc ram?
Hello ravindrao5,
This board only compatible with ECC memory.
Charlie_Intel
Hello ravindrao5,
Charlie_Intel
Hello ravindrao5,
We are wondering if you have further questions?
Charlie_Intel
Hello ravindrao5,
You are welcome if you have further questions do not hesitate to contact us back.
Charlie_Intel
