Server Products
Data Center Products including boards, integrated systems, Intel® Xeon® Processors, RAID Storage, and Intel® Xeon® Processors
4663 Discussions
Intel Serverboard S5520HCT and Windows Hyper-V 2008 R2 NIC SLOOOOW
Hi All,
Having an issue with this board and the onboard NIC's - 82576.
Fresh install of OS we see data transfer of ~100M
Add roll Hyper-V (do not select to create a virtual switch)
reboot
Do a transfer again and network speed drops to ~5M
Remove Roll Hyper-V
Reboot
Speed back to normal
Thing tried when Hyper-V roll added;
Disbale selective/all offloading
Disbale flow control
disbale chimney in netsh and or RSS
Play with buffers settings
We have 3 new servers all with the same issue any ideas please?
Michael.
Have you tried setting your NIC's to 1GB Full Auto?
Hi Patrick,
Yes the NIC's are setup for Gg Full duplex- using auto neg on both cards (all 6 ports) and Brocade Fastiron Super X switch.
I have also disabled in Windows all NIC's before adding Hyper-V and then rebooting and reenabled 1 NIC - same result.
We do have Four other Win2008 R2 servers running Hyper-V fine - these are an older gen Intel Server
These older gen boards are - BIOS Version/Date Intel Corporation S5000.86B.12.00.0098.062320091136, 23/06/2009
DSilv11
Valued Contributor III
A number of folks have reported Hyper-V issues related to this generation product.
A fix is expected very shortly. (BIOS update. Version number not available till it completes testing)
One work-around seems to be to run 32G or less of ram.
Hello Doc_SilverCreek,
I have taken our 16GB of RAM - this leaves 32GB in the system. By doing this it appears to have doubled the network throughput.
This is still under half of the throughput when Hyper-V has been removed though.
As we are a Intel Premier Channel Partner we will also continue to push our contacts at Intel to see if this is what is happerning with this board.
We also have a case open with Microsoft - so I will post the finds to this issue when we get to the bottom of it.
Thanks for your help here.
