Server Products
4953 Discussions
Intel axxp3swx08080 card JTAG connector pinout
alex_brown2
can anyone help me with JTAG connector  (J1A2) pinout on axxp3swx08080 PCIe Gen3 x8 Switch AIC?
JoseH_Intel
Hello alex_brown2,
As per the AXXP3SWX08080 revision, we didn't find any cables or JTAG connector present on this card,
Could you please share the following information:
  • Photographs of the cable needed and the port where it needs to be connected from both sides (AXXP3SWX08080 and server board port),
  • An example of the purpose of connecting to this port and what settings are you trying to modify
  • Additionally please share your company information, since it may require NDA.
We will look forward to your updates.
Jose A.
JosafathB_Intel
Hello, alex_brown2.
Thank you for contacting Intel® Memory and Storage support.
We have a forum for Server Products, and we are moving this thread to that forum so you can get an answer to your inquiry as soon as possible.
Jos B.
Intel® Customer Support Technician.
Victor_G_Intel
Hello alex_brown2,
To continue with your request can you please provide the following information:
  1. What will be the exact Intel server system model that you have this product installed on?
  2. Can you also share with us your motherboard model?
  3. Is there a particular reason you need the TAG connector (J1A2) pinout? Is the Add-in-card working?
Victor G.
alex_brown2
Hello,  Victor_G_Intel.
Thank you for reply.
I use AXXP3SWx08080 add-in card in my workstation, considering it as a kind of non-expensive RDK
to work with Microchip PM8533B PCIe switch.
The card works perfectly.
I need JTAG connection to play with different modes and configurations of the switch.
JoseH_Intel
Hello alex_brown2,
Please allow us some time to check if this pinout information is publically available. Take into consideration that some design information might require a Corporate Non-Disclusure Agreement. We will get back to you soon
Jose A.
JoseH_Intel
Hello alex_brown2,
Jose A.
alex_brown2
Hello JoseH_Intel,
The picture of the AXXP3SWX08080 JTAG (eJTAG?) port which is need to be connected is attached.
Actually, I solved my task. Thank you for the brilliant piece of hardware.
