I have intel server se7520jr2 motherboard, and i have Intel management module professional edition. When i installed a new (IMM) board i flashed the firmware then i flashed the frusdr. which then made my fan speed kick to max speed. How can i work around this? I have tried downgrading firmware and frusdr.I have tried choosing different chassis i have disabled all fans and i have enabled all fans and i still have not found a solution.Thank GUYS!
- Tags:
- Modules
Which chassis are you using, and did you select the correct chassis during FRUSDR update? Check the fan connections. Run https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=7470&lang=eng System Event Log Viewer to check for errors.
