Server Products
4762 Discussions
Intel pstate driver for IceLake
CChong
My Ubuntu 20.04 (kernel 5.11.0-40-generic) and Rocky Linux 8.4 both report that IceLake CPU is not supported in my Supermicro X12DDW-A6 motherboard (PCH C621A)
https://www.supermicro.com/en/products/motherboard/X12DDW-A6
dmesg |grep intel_pstate
[ 2.897675] intel_pstate: CPU model not supported
The system is using acpi-cpufreq to manage the cpu.
I just wonder if this is this a known issue?
Also, when I do the command below, I can see the interrupt 6C is running.
My questions:
1) What type of interrupt is it?
2) How do I find which ACPI module that cause this issue?
grep . /sys/firmware/acpi/interrupts/* |grep gpe6C
/sys/firmware/acpi/interrupts/gpe6C: 40208 EN enabled unmasked
/sys/firmware/acpi/interrupts/gpe6C: 40210 EN enabled unmasked
# grep . /sys/firmware/acpi/interrupts/* |grep gpe6C
/sys/firmware/acpi/interrupts/gpe6C: 40212 EN enabled unmasked
Appreciate if someone from the community can comment on this and give me some hints.
Chris
SergioS_Intel
Hello CChong,
Thank you for contacting Intel Customer Support.
Can you please provide us the model of the Intel(R) processor that you are using?
Sergio S.
For firmware updates and troubleshooting tips, visit :https://intel.com/support/serverbios
CChong
Hi Sergio,m
Here is the CPU information
model name : Intel(R) Xeon(R) Gold 6330 CPU @ 2.00GHz
stepping : 6
microcode : 0xd0002e0
cpu MHz : 800.000
cache size : 43008 KB
Chris
SergioS_Intel
Hello CChong,
We appreciate the additional information, have you tried to contact SuperMicro and confirmed if the motherboard and the processor are indeed compatible? Additionally, have you tried to ask them information that you need? We do not have any know issues at the moment, what we recommend is to test your processor on a fully compatible system and check if it is working.
Sergio S.
SergioS_Intel
Hello CChong,
We are following your thread and we were wondering if you were able to contact your motherboard manufacturer.
Sergio S.
SergioS_Intel
Hello CChong,
We are following your thread and we were wondering if you need further assistance.
Sergio S.
Victor_G_Intel
Hello CChong,
We have not heard back from you.
If you need any additional information, please submit a new question as this thread will no longer be monitored
Victor G.
