Server Products
Data Center Products including boards, integrated systems, Intel® Xeon® Processors, RAID Storage, and Intel® Xeon® Processors
4611 Discussions
Intel rmm3 problem
Hi.
I have Intel rmm3 installed on one of my servers
Smash CLP Version :SMASH 1.0.0/CLP 1.09
Somehow web is not working (page loading), but i do have ssh access. Is it possible to reboot server from console?
Thank you.
JasonT_Intel
You can perform a remote reset under the menu Remote Control -> Server Power Control, there will be options to choose depending on what you want to do when performing a cold/hard reset.
You should be able to cd to system1 and type command reset to reset server. I have the same issue, but I can not bring my server down. I am looking forward to reset BMC.
Mihir
TAvip
cuz search requests like "Reset BMC via SMASH-CLP Console" led to this page, I think we need a solution here, so if anyone face with such a problem - he could deal with it. I hope so.
Case:
problem with BMC web-panel, neither HTTP nor HTTPS is loading properly.
1st solution (if SSH still works):
login to Smash CLP via ssh, and run next few commands:
cd /system1/sp1/enetport1/lanendpt1/ipendpt1
set committed=0
set committed=1
This will reload BMC, so perhaps you'll gain access.
2nd solution (if you have only access to the system running on the server):
first, install IPMI management utilities - ipmiutil. Then run the command below:
ipmitool bmc reset cold
This will restart BMC, without affecting the server itself.
If you have remote access, but first solution for some reason didn't help you - you can use ipmitool with remote host as showed in next command (don't forget to install ipmiutil on client host):
ipmitool -H hostname -U username -P password -v bmc reset cold
You must change the hostname, username and pasword in command to your own.
AGonz21
Thanks. First solution no, but second solution works for me.
DSilv11
Valued Contributor III
The third is usually the recommended since you can send it remotely over the network as well.
