Hey guys,
I recently got my hands on an s5520hc setup with dual x5690 Xeons for a good price. I plan to use it for some visualisation experiments. I successfully build the system and upgraded BIOS etc. to the newest software. But the system is schowwing an error, the CPU0 Fan check LED is glowing ember, I assume that means that there's a Problem with the cpu0 fan. I checked in Windows and the fanspeed is normally showing up. There are also no thermal problems. As an result of that error the fans are spinning at full throttle, and thats pretty annoying in the livingroom. Do you guys have any suggestions or solutions for this problem?
My config:
Mainboard: Intel s5520hc
bios version: R0069
cpu: 2x Xeon X5690
Ram: 96gb
Fans: 6 case fans, 2 CPU fans
psu: Sharkoon WPM Gold Zero 750w with two 8 pin eps connectors
gpu: gt730s
Hello Johannes3,
Thank you for joining the community
Due to this product being discontinued, Intel Customer Service no longer supports inquiries for it, but perhaps fellow community members have the knowledge to jump in and help. You may also find the Discontinued Products website helpful to address your request. Thank you for understanding.
The available support website for legacy systems is found here:
Jose A.
