Server Products
4984 Discussions
Ipmitool lan print 1 returns Invalid channel: 1
RandallL_S_Intel
Prior to replacing the 3V battery on the mother board, this command: "Ipmitool lan print 1" returned useful information. Now the command returns: Invalid channel: 1.
Did I lose a configuration setting and if so, what change do I need to make?
Hello rlsmith,
Thanks for joining the community.
I understand your issue but before telling you anything could you please specify what server board model are you referring to exactly? Where are you trying to run this command at? EFI shell? What other chances have you done recently besides changing the CMOS battery that obviously reset BIOS to defaults?
Jose A.
Hello rlsmith,
Do you have any updates, questions or comments in regards to this issue?
Please do not hesitate to contact us back.
If you consider the issue to be completed please let us know so we can proceed to mark this thread as resolved.
Jose A.
RandallL_S_Intel
Jose,
Thank you for the reply.
The commands were executed from the CLI as root logged into the system. The BIOS and BMC firmware were updated on 3/15/18 and this command (ipmitool lan print 1) worked after the upgrade and a power cycle. The only change I made was to set the dedicated lan interface in the BMC to STATIC and assign a static IP address. The original setting was Dynamic and the NIC bound to address: 10.2.3.252. Interestingly enough, the system still responds to a ping at 10.2.3.252, but when booting into the BIOS, the setting is static and the address 10.2.100.126.
Here are the results of running two ipmitool/util commands:
[root@onyx-126 ~]# ipmitool lan print 1
Invalid channel: 1
Also this command fails with more information:
[root@onyx-126 ~]# ipmiutil lan -r
ipmiutil ver 3.08
ilan ver 3.08
-- BMC version 1.51, IPMI version 2.0
This system does not support IPMI LAN channels.
ipmiutil lan, request not supported
Here are the details on the system board:
Board Mfg Date : Wed Apr 15 18:45:00 2015
Board Mfg : Intel Corporation
Board Product : S2600WT2
Board Serial : BQWL51650348
Board Part Number : H21573-360
Product Manufacturer : Intel Corporation
Product Name : S2600WT2
Here are the details on the BMC:
ipmitool mc info
Device ID : 33
Device Revision : 1
Firmware Revision : 1.51
IPMI Version : 2.0
Manufacturer ID : 343
Manufacturer Name : Intel Corporation
Product ID : 111 (0x006f)
Product Name : Unknown (0x6F)
Device Available : yes
Provides Device SDRs : no
Additional Device Support :
Sensor Device
SDR Repository Device
SEL Device
FRU Inventory Device
IPMB Event Receiver
IPMB Event Generator
Chassis Device
Aux Firmware Rev Info :
0x01
0x07
0x86
0x2b
Any assistance is greatly appreciated.
Rlsmith
Hello rlsmith,
Thanks for the info provided.
The fact that your system pings to the previously set IP address makes me think that there are some older configurations still saved in the BMC. Sometimes when weird issues like this happen we can try to do a BIOS defaults (F9) and then save changes and reboot. Could you please try this, even when it sounds repetitive, and let us know. Of course you will need to setup the BMC IP address again.
Jose A.
RandallL_S_Intel
Hello Jose,
I've reset the BIOS and configured the dedicated NIC to the address I want to use. Now, neither address responds to a ping and the ipmitool lan print 1 command continues to fail. Ipmitool will return the MC information as before. Do you have any other suggestions as to how I can get SOL working again?
Thanks again,
rlsmith
Hello rlsmith,
We will try to replicate your issue in our labs. We will keep you posted with our findings.
Jose A.
Hello rlsmith,
We would like you to try a peer to peer connection between the server BMC port (previously setup with an static IP address and subnet mask) and a computer or laptop also with a static IP address and subnet mask. Try to access the BMC console directly from the computer. If it works then there is no problem with the BMC management port. At this point you could try to run the ipmi command. If the previous steps works fine then it is possible that your issue is network related.
Let us know how it goes
Jose A.
Hello rlsmith,
Jose A.
Hello rlsmith,
We will proceed to mark this thread as resolved. If you have further issues or questions just go ahead and create a new topic.
Jose A.
