Server Products
Data Center Products including boards, integrated systems, Intel® Xeon® Processors, RAID Storage, and Intel® Xeon® Processors
4663 Discussions
Is the AXXRMM4LITE2 module compatible with a S2600CP4 board?
VArkh
I have a system with a S2600CP4 board. I would like to enable its KVM features by adding a remote management module that works with this board (AXXRMM4 or AXXRMM4LITE).
Since I don't necessarily need a dedicated NIC for remote management, I'm mostly looking for the AXXRMM4LITE. However, I'm having a hard time finding one in stock.
AXXRMM4LITE2 seems easier to find but isn't compatible with the S2600CP4 board, according to the Intel site here: https://ark.intel.com/products/91525/Remote-Management-Module-4-Lite-2-AXXRMM4LITE2%23%40compatibility Remote Management Module 4 Lite 2 AXXRMM4LITE2 Product Specifications
The AXXRMM4LITE2 module does look identical to AXXRMM4LITE, so I was wondering if anyone knew if it could be compatible after all?
Hello Vitaly,
Thank you for contacting Intel(R) Technical Support.
I understand that you want to confirm if the Intel(R) S2600CP4 is compatible with the AXXRMM4LITE2.
I checked the Technical Product Specification for the Server board and the module AXXRMM4LITE2 is not showing as compatible with the server board. The only modules compatible are the AXXRMM4LITE and the AXXRMM4. You can confirm this by checking the following https://www.intel.com/content/dam/support/us/en/documents/motherboards/server/s2600cp/sb/g26942005_s2600cp_p4000cp_tps_rev19.pdf link.
I hope this information helps to clarify your inquiry.
Jeremiah A.
Hello Vitaly,
Jeremiah A.
VArkh
Thanks for the quick response. This module has not been tested with the motherboard or is it really not compatible?
Hi Vitaly,
Thank you for your update.
The module AXXRMM4LITE2 isnot compatible with the Intel(R) Board S2600CP4.
You can confirm compatible Server boards for this module https://ark.intel.com/products/91525/Remote-Management-Module-4-Lite-2-AXXRMM4LITE2# @compatibility here.
Jeremiah A.
