Which motherboard are you using? The attached logs don't have much information - what are you actually seeing, when this happens?
This is intel Alcolu S5000PAL.
I'll attach the on screen message
Are you using the latest version for that board? The name and version from your screenshot don't look the same as
http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=18440&lang=eng
