hi~
I woder how to enter KNL BIOS to modify MCDRAM's mode
Hello Woder,
To access to processor features you will need to access the board main BIOS.
You need to access the BIOS with F2 during the POST prompt, then go to Advanced>Processor Configuration.
To learn more about any of the available options go to the following URL: http://www.intelserveredge.com/assets/S7200AP_HNS7200AP_TPS_R1_0.pdf http://www.intelserveredge.com/assets/S7200AP_HNS7200AP_TPS_R1_0.pdf on page 21 Processor Support section.
Hope this helps
Jose H.
thank you!
we are stopped by the biggest problem "how to enter BIOS GUI",by attemption, it is so magic that we can use the remote console can enter the BIOS GUI!
ps:(some tips for others remote console is supported by integrated BMC web console( you need to use a Ethernet cable to connect your notebook to KNL and enter 192.168.0.11) )
Hello Woder,
There is an internal VGA header on the board that you can use to connect any regular VGA monitor and access the video signal. Once there you should be able to see to POST screen and access the BIOS when prompted.
For more info go to page 61 of the following URL: http://www.intelserveredge.com/assets/S7200AP_HNS7200AP_TPS_R1_0.pdf http://www.intelserveredge.com/assets/S7200AP_HNS7200AP_TPS_R1_0.pdf
Jose H.
Hello Woder,
Do you have any updates about this case?
Please let me know.
Jose H.
