We will be moving the location of our server to a room that has fiber optic internet cables. As a result, I want to add the ports that will let us connect to the fiber optic 10G lines which requires using SFP+. In the datasheet, it just specifies SFP+ LAN Riser Option to do so, so I am unsure which one to purchase to use.
I saw on this support post that the recommended devices is the AXXSTSFPPKIT. However, I see that this device has been discontinued. Is there a newer version of this device? Do either of these options work (X520-DA2 or Intel X710-BM2) work or do I need to find a AXXSTSFPPKIT)
In general advice on making this switch from Ethernet to SFP+ Fiber Optic is also appreciated.
Ray
Idaho Tech Solutions
Hi Ray,
Thank you for the response. Do you know if the AXXSTSFPPKIT is recommended over the Ethernet Converged Network Adapter XL710-QDA2? I have seen the latter in compatible components for SFP+ Adapters.
Best,
Roy
