Server Products
4653 Discussions
Lost access to volume due to connectivity issues on Vmware ESXi 4.1.0
Seagate ST32000644NS SATA Disk Lost access to volume due to connectivity issues.
Problem Description
I have build a server with harware listed below.
I have installed on it vMWare ESXi 4.1.0.
I update Firmware al latest version.
I use Seagate ST32000644NS SATA Disk for virtual machines backup.
During Backup an error occur:
vmWare ESXi logs report:
Lost access to volume 4e5f62ca-e0b2e6f0-9f41-001e6716b77f (local-sas-
a02-raid1-data) due to connectivity issues. Recovery attempt is in
progress and outcome will be reported shortly
# HARDWARE INVENTORY
01 http:///http://www.elledi.it/shop/product_info.php?products_id=52288470 Chassis INTEL SC5600LX SC5600LX COOLING & REDUNDANT NO HEAT SINKS & NO POWER CORD
01 http://www.elledi.it/shop/product_info.php?products_id=52288473 INTEL AXXLCPPED LCP PED PRODUCTION FOR SC5300
01 http://www.elledi.it/shop/product_info.php?manufacturers_id=&products_id=54131771 INTEL FRIGTHSFANKIT HOT SWAP FAN UPG KIT SC5600 WITH ACCS
01 http://www.elledi.it/shop/product_info.php?manufacturers_id=&products_id=45914692 INTEL AXX6DRV3GEXP 6-DRIVE SAS/SATA BACKPLANE FOR SC5400BRP/SC5400LX WITH EXP
01 http://www.elledi.it/shop/product_info.php?manufacturers_id=&products_id=52288469 Motherboard INTEL S5520HCR HANLAN CREEK S5520HC 12 DIMM 12 DIMMS SINGLE BOX REFRESHED
02 http://www.elledi.it/shop/product_info.php?manufacturers_id=&products_id=52288471 Cpu INTEL BX80614E5620 XEON E5620 2.40GHZ 5.86GT/S SKT1366 12MB BOXED W/O HEATSINK
02 http://www.elledi.it/shop/product_info.php?manufacturers_id=&products_id=49857795 INTEL BXSTS100C THERMAL SOLUTION (COMBO) FOR INTEL XEON CPU SKT1366/1155
06 http://www.elledi.it/shop/product_info.php?manufacturers_id=&products_id=52783241 Memoria KINGSTON KVR1333D3D4R9S/4G 4GB 1333MHZ DDR3 ECC REG W/PARI TY CL9 DIMM DUAL RANK, X4 W/THER
01 http://www.elledi.it/shop/product_info.php?manufacturers_id=&products_id=49990929 RaidController Intel RS2BL080
02 http://www.elledi.it/shop/product_info.php?manufacturers_id=&products_id=45914689 Disco SEAGATE ST3146356SS CHEETAH 15K.7 145B 3.5IN 15KRPM 16MB SAS
02 http://www.elledi.it/shop/product_info.php?manufacturers_id=&products_id=49990932 Disco SEAGATE ST3600057SS CHEETAH 15K.7 600GB 3.5IN 15KRPM 16MB SAS2
01 http://www.elledi.it/shop/product_info.php?manufacturers_id=&products_id=51799657 Disco SEAGATE ST32000644NS CONSTELLATION ES 7200.1 2TB 3.5IN 7200RPM 64MB SATA/300
01 SistemaOperativo vMWare ESXi 4.1.0
# VmWare ESXi 4.1.0 LOG
progress and outcome will be reported shortly.
info
15/09/2011 09:45:13
localhost.localdomain
# Controller INTEL RS2BL080 LOG
seqNum: 0x00000c58
Time: Wed Sep 14 20:01:02 2011
Code: 0x0000010c
Class: 1
Locale: 0x02
Event Description: PD 0d(e0x0c/s5) Path 5000e0ce395b9006 reset (Type 03)
Event Data:
Device ID: 13
Enclosure Index: 12
Slot Number: 5
Error: 3
seqNum: 0x00000c59
Time: Wed Sep 14 20:01:05 2011
Code: 0x00000057
Class: 1
Locale: 0x02
Event Description: Error on PD 0d(e0x0c/s5) (Error f0)
Event Data:
Device ID: 13
Enclosure Index: 12
Slot Number: 5
Error: 240
seqNum: 0x00000c5a
Code: 0x00000072
Class: 0
Locale: 0x02
Event Description: State change on PD 0d(e0x0c/s5) from ONLINE(18) to FAILED(11)
Event Data:
Device ID: 13
Enclosure Index: 12
Slot Number: 5
Previous state: 24
New state: 17
seqNum: 0x00000c5b
Code: 0x00000051
Class: 0
Locale: 0x01
Event Description: State change on VD 02/2 from OPTIMAL(3) to OFFLINE(0)
Event Data:
Target Id: 2
Previous state: 3
New state: 0
seqNum: 0x00000c5c
Code: 0x000000fc
Class: 3
Locale: 0x01
Event Descrip...
Edward_Z_Intel
From the RAID log, drive in slot 5 failed and caused the VD offline. First of all, you should not mix SATA and SAS drives in the same enclosure. See http://www.intel.com/support/motherboards/server/sb/CS-030795.htm http://www.intel.com/support/motherboards/server/sb/CS-030795.htm. Main reason is that SAS drives have higher RPM and thus generates more vibration, which may cause SATA drives performance degrade, or even offline.
Also please make sure your http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=20174 RAID firmware and http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=20245 backplane firmware are updated.
