Is the MFS5000SI compute module supported in an MFSYS25V2 chassis running firmware v11.6?
No it's not.
For what it is worth, the MFS5000SI compute modules do continue to operate after upgrading to version 11.6. The only potential issue is that Intel may no longer provide technical support (I am not sure about this) if you have any issue. But the bottom line is that after upgrading the firmware to 11.6, the compute module does still function properly (which is good since downgrading the firmware isn't supported).
Jason
