Server Products
Data Center Products including boards, integrated systems, Intel® Xeon® Processors, RAID Storage, and Intel® Xeon® Processors
4808 Discussions
MFS5520VI no post.
HAl-B
So one of the modules on the IMS is not posting. According to the CMM:
Status: OK, ON
Under the Events tab:
Watchdog timer expired - The server was hard reset
BIOS FRB2 Watchdog timer expired - The server was hard reset
In the Firmware section of the Settings:
Server 1: (no post server)
BMC Firmware OK 1.27.1
BMC Boot OK 0.28
BIOS unknown
The post code LEDs are the following
A= Amber
G= Green
X= Off
XXAAXGXX (with Emergency Bios jumper set to 2,3)
AXAAGXXG (with Emergency Bios jumper set to 1,2)
If I do remove all memory modules, I do get the expected 3-beeps.
Right now my attempts are at a single CPU and 3 sticks or RAM. The CPU is an Intel Xeon 5620. I will be attempting a CPU swap and see where it goes from there.
Any thoughts?
Edward_Z_Intel
Try if your memory is in http://www.intel.com/support/motherboards/server/MFS5520VI/sb/CS-030649.htm Tested memory list. Try one DIMM at a time.
