Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
MFSYS25+VLAN+VMWARE
Hello, sorry for my English. Please help me, I'm not so customizable.
Objective: Connect the external port to the virtual machine.
I use this article: http://www.intel.com/support/motherboards/server/sb/CS-031599.htm# 3-Many-One http://www.intel.com/support/motherboards/server/sb/CS-031599.htm# 3-Many-One
1. Сreated a VLAN
2. Changed the port PVID (Ext.1)
3. Here is the VLAN 1 - Default
4. Here is the VLAN 11 - my
5. Then I added the VM Network (VMNetwork to Web)
6. The properties changed VM network.
What am I doing wrong?
Highlighted
Re: MFSYS25+VLAN+VMWARE
Do you have VLAN 11 set to tagged, or untagged, inside the virtual switch? It should be tagging packets.
If you are not going to have more than one VLAN on that virtual switch, you could also change everything over to untagged.
