Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
MFSYS25 and it's CMM
I have a MFSYS25 Version 1 modular system. I have not been able to access the management card because no one knows the password. We eventually bought a new (refurbished) CMM and plugged it in. However, it pulled the same IP address and configurations as the old one. Have I just caused myself to have a paperweight? Is there a way to get into these cards?
I attempted to use this link several times. I can watch the CMM booting progress but I can not get to an EBF:
http://www.intel.com/support/motherboards/server/sb/CS-029107.htm Intel® Modular Server Systems — Cannot log in to CMM
Thanks for any help you can give.
Highlighted
The MFSYS25 keeps a copy of the configuration on an SD card on the midplane, so swapping CMMs won't reset IP or password. You did find the right web document to follow, though. If you can't get the prompt to respond, check the note at the bottom of that page:
If you see the boot process, but cannot get the EBF prompt, please note that the serial cable or USB to serial cable must be a fully populated straight through cable. Specifically, it must allow the host PC to assert the CTS pin on the CMM.
Highlighted
Hi All,
When I clicks http://www.intel.com/support/motherboards/server/sb/CS-029107.htm http://www.intel.com/support/motherboards/server/sb/CS-029107.htm, It takes me to http://www.intel.com/content/www/us/en/support/boards-and-kits.html http://www.intel.com/content/www/us/en/support/boards-and-kits.html instead of CS-029107 document.
Does anyone of you guys have saved page of CS-029107 document ( Intel® Modular Server Systems — Cannot log in to CMM ) ?
Community Manager
This post was answered on thread:
