Software included with board is ISM ver 2. Would like to install the simplest software set to monitor this server's hardware. Install CD points toward instaling Microsoft System Center Essentials, which appears to me to be overkill(?).
Is there a new version that would give me just the local agent and a console to see the monitored items? Thank you!
I checked all the downloads available at http://www.intel.com/support/motherboards/server/s3200SH/index.htm - doesn't look like there's any other utility.
