Server Products
Data Center Products including boards, integrated systems, Intel® Xeon® Processors, RAID Storage, and Intel® Xeon® Processors
4614 Discussions
Manager servers from Win7-64?
BWait
I'm trying to get remote management working on an older SE7520BD2V server board with the Advanced Edition IMM module installed.
The IMM is configured and working properly as I can go to the configured IP in a browser and get the basic management options. I can also retrieve information from this system from a remote system with command-line IPMI tool.
However, I'm unable to connect from Intel Server Manager (ISM) 8.50. I can discover the IMM IP but when I try to connect, it complains with "Invalid IPMI BMC credentials. Please type in the correct user name and password."
I'm wondering if this could be because I'm running from Win7-64?
If not, what else can I try?
I tried to install the newer Multi Server Manager, but that requires IPMI/BMC on the system from which it's run. I only have ASF on this workstation board. Is there another Intel server management package that's newer than MSM?
Brad
Edward_Z_Intel
Did you try to setup another BMC user, besides the default anonymous user?
