Hi! I have mainboard S2600WT2R with memory 8*8 M393A1G43DB0-CPB and two processors.
In order to work in 4-channel mode, I have to put 8 more DIMMs? What memory analogue to put, memory M393A1G43DB0-CPB is more sold.
Hello Amigo83,
Probably the same model number memory might be hard to find. But if you a search in google you find some websites that still have this memory.
Also, you could match the same configuration and it should work.
Match the GB and the MHz and the latency and should not have any problems.
Or you could try to sale the memory you have and purchase all the modules you need from a new manufacturer.
For memory information this system board is able to work with compatible teste by Intel:
https://ark.intel.com/products/88277/Intel-Server-Board-S2600WT2R https://ark.intel.com/products/88277/Intel-Server-Board-S2600WT2R
https://ark.intel.com/products/88277/Intel-Server-Board-S2600WT2R# tab-blade-1-1 https://ark.intel.com/products/88277/Intel-Server-Board-S2600WT2R# tab-blade-1-1
If there is anything else we can help please feel free to ask.
Henry A.
Hello Amigo83,
I just will like to follow if there is anything else I can help you with your memory questions for the S2600WT2R system.
Henry A.
Hello Amigo83,
I am sorry but I haven't heard back from you. I will proceed on closing the threath, if you have any futher question we can open a new and referr back to this.
Thank you for your time and patience.
Henry A.
