Hello folks
Can someone help me figure out if it is possible to mix quad and dual rank FBDIMMs on the S5000PSL?
I have been looking at the Technical Product Specifications v1.7 and it has a short section on quad rank, but I'm not sure i understand it correctly.
I currently have populated 4 of the 8 sockets using 4GB QUAD rank FBDIMMs for a total of 16GB.
Can I also put in an additional two dual rank 4GB FBDIMMs?
Thank you in advance.
Best regards
Dfir
Ideally it should be OK, but I can't not promise compatibility since the configuration hasn't been tested. And, it's always tested to use memory from http://www.intel.com/support/motherboards/server/s5000psl/sb/CS-022924.htm Tested memory list.
