Server Products
Data Center Products including boards, integrated systems, Intel® Xeon® Processors, RAID Storage, and Intel® Xeon® Processors
4778 Discussions
More 7 pin SATA ports for S2600CWTR
MBrom3
I have a number of S2600CWTR boards .... these boards have two 7-pin SATA ports. What do you recommend for people that need more ... is there an add-on SATA controller that you recommend?
To answer your question, you can try using a add-on SATA controller but this type of card has not been validated from Intel so the chances it will work are 50/50. Most of our Intel server boards have two 7-pin SATA connectors so you can also check for different third party options in the market.
