Server Products
Data Center Products including boards, integrated systems, Intel® Xeon® Processors, RAID Storage; and Intel® Xeon® Processors
Welcome to the Intel Community. If you get an answer you like, please mark it as an Accepted Solution to help others. Thank you!
For the latest information on Intel’s response to the Log4j/Log4Shell vulnerability, please see Intel-SA-00646
4329 Discussions
Motherboard Intel server S2600WT show watchdog asserted, what is root problem ?
TTrin3
Hi all,
I just changed a new MB for intel server. This MB has model S2600WT.. After assemble all parts in this server and plug the power cable, System self check for a few second, everything seem be ok. When I press power switch on, all fans running up at high speed and not slow down as normal, The front LCD of system show orange color with error " Watchdog asserted" and system is not show video too.
Please kindly help me to explain what is root problem and how to fix it.
Thanks and best regards
Trinh Nguyen
Community Manager
Please contact our support group directly in order to review the server system logs and narrow the issue based on that report:
http://www.intel.com/content/www/us/en/support/contact-support.html http://www.intel.com/content/www/us/en/support/contact-support.html
Community Manager
